WorldSemi has a new chipset: WS2821
http://www.world-semi.com/uploads/soft/140305/1-140305102109.pdf
- Signal adopts the single line parallel connection type,any pixels’ failure won’t effect other pixel’s
display effect.
- Signal can compatible and expand the DMX512(1990) protocol signal.
- Data transmission speed is 250Kbps~750Kbps.
- The built-in voltage regulator chip, 5V above 24V power supply only series resistance to IC VDD feet, without additional voltage regulator tube.
- WS2821 IC has VR-tube(voltage-regulator tube) built-in,for higher than 5V,lower than 24V’s power supply,only require one resistor being series
connected to the IC’s VDD pin,no need to add the VR-tube outside.
- Output voltage can bear 24V
- R/G/B out three channels’ output,each output driven channel has PWM circuit to control the gray,256 gray is adjustable
- R/G/B output default current 19mA,maximum 60mA.
So, built in v-reg is nice, although having just bought 50 dc:dc converters
sucks to be me!
Speed looks to be on a par with WS2811/WS2812.
Just confirmed with WorldSemi - Yes, they speak SPI and DMX (1990) and can accept voltages up to 24V.
Sorts out any problem I may have had with auto voltages…
“voltage-regulator tube”?!
Translation isn’t their strongest trait …
I need a translation to English from autotranslated-Chinese-to-English.
I can barely spek Ingirsh and I are one.
Wow, they’ve managed a transmission rate that makes the ws2812s look downright speedy!
I did raise that question with them - they said the speed was the same - it is essentially the same chip with added DMX capabilities and higher voltage support.
Yeah - and the 2812 speed is pretty damn shitty, and the moment someone gets a 10-20mbps rate 5050 w/embedded controller, I’m going to drop using 2812s for personal projects like and emflamed potato.
Here’s a hint, they’re coming.
The issue I have is weight - 4 wire weighs more than 3-wire. Not that bothered about speed - the 1kHz I get from WS28* is more than enough.
That being said, I have had my appreciation of the variety of LEDs expanded greatly on here and if I could find an appropriate controller/LED/speed combination, I would definitely give it a try.
Something with 10MB/s and 240V would do nicely
Start doing stuff with hundreds, if not thousands of LEDs, and wanting to maintain 30+ fps, and let’s see if you still don’t care about speed
If I could afford thousands of LEDs, I’m sure I would appreciate the problem… on a fixed income, I’m lucky to scratch together the $11 for a 30-led string
