Would any one be willing to print some parts for me at cost +
Would any one be willing to print some parts for me at cost + shipping?
What is it?
Depending on the complexity of the print, I might interested.
BTW, did you know about this?
http://forums.reprap.org/list.php?163
I have a couple things I will need. A set of prusa i3 parts and a custom case I’m working on.
I had a local guy helping me with it but he has gotten busy and dosnt have the time.
Yea I will check there if I don’t find some one here.
I’m in central ohio if any one is close that would be even better as I could just pick the prints up.
Could you post some renders of them?
I have the ability on the Makerbot rep2x level but would be open to having some students give it a go in Sept.
Yeah I could try in my basement at the moment but this would be a cool way to expand outside of the classroom walls and show students a different side of 3d printing.
Sure here are a couple renders of the bottom and top.
Hi Mike my girl fowarded me your post. What is the size?
bottom - 57mm x 78mm x 15mm
top - 57mm x 78mm x 4mm
I should be able to print that no problem, what colors and what material, ABS or PLA?
I have been using black PLA but in the end I’m not picky as right now I’m just trying to get the fit and location of all the ports correct.
I can print it in black PLA, how much do you want to pay and when do you need it?
I had been paying the guy $5 to get it printed and it was running a bit under 3 hours to print.
I would like to have repetitively little fill when printed as the last one I had done ended up with two walls and no support between them for the sides.
Let me know what you think.
$5 sounds fine, how thick are the walls?
1.5mm thick. I will add you and get you my contact info and what not.
Ok. Sounds good Mike
