Would anyone using smoothie for the Herculien be able to send me the smoothies code for me to flash on to the board? I am close to finishing the printer although I have not been getting responses back when I send simple g commands. The printer can run the breakin code just fine, I just have problems when it comes to auto pid and other things.
@Gunnar_Meyers The smoothie config that I am using is here: https://www.dropbox.com/sh/383x6ziztxt6r3m/AAAm6J2C6wdX3QlaBZAVmnaFa?dl=0
However, it should be noted: You’ll have to make sure you are using the same pins as I am for the bed, the hotend (I’m only using 1 currently), the cooling fan, fan for the hotend, etc.
Rather than copying what I shared onto the SD of your smoothieboard(?.. the azteed X5 also runs smoothieware), I recommend you compare your current config file and make sure you understand what each is controlling.
