Is there a way to add another stepper output to be used for an addition extruder?
I’m currently building my own delta printer and saw Thomas Sanlanderer’s live stream recently with him installing a smoothie board to an Atom 2.0.
I want to use a diamond tri extruder with the printer that I’m building.
I’m planning on using a heated bed with it.
if there is a module that I can add on, it would be ideal, but if I have to put together one, I don’t mind the work, I would need some sort of instruction though.
Thanks, I don’t have a board yet.
I’m planning on getting a smoothieboard X5.
I was looking at the BBP 1s, because of it’s 7 stepper motor outputs, but looking at their indiegogo page, it seems that they took the money and disappeared, from reading some of the backer’s comments.
So looking at the link, from what I can tell, the pins mentioned seem to be the same IO pins/connections as the M1, M2 …. connections for using a separate driver.
Is this correct or are they separate IO pins from those?
Because for what I want to do, I would need 6 stepper motor outputs.
You can use any pin on the board to control stepper motor drivers. You just need two pins ( step and dir ) for a drive.
The on-board drivers breakout their pins, but there are also “free” ( un-used ) GPIO pins broken out on the board.
See http://smoothieware.org/pinout
You definitely can run 6 steppers no problem.
Thanks, that helps a lot.
I’ll be ordering one with in the week.
As soon as I get it, I’ll cnc a daughter board for it… unless there are already breakout boards for it.
I figured. I just want to make one for ease of install and maintenance. After dealing with my other 2 printers, I don’t want to deal with the nest of wires that usually happens.
