Xyz da vinci, is verry reliable, you can count on it to fail!
If a print on XYZ failed, its because you’re doing something wrong. XD
@Xenomorpheus same is true with anything, xyz thinks so highly of themselves, they didn’t make it easy to fix? That’s what makes things shit!
Honestly havent had any problems with mine. Im not seeing what went wrong with your brass knuckles.
@Xenomorpheus it’s hot end failure, it likes to just stop heating, it’s had the resister burn out and soldered over with 4a fuse added , 10 min into the print, no heat and everything is clogged up! Sometimes it makes it farther, but never completes a print
Really? Ive not encountered an issue like that
Maybe you have a loose connector or a bad crimp job. As the metal in the connector or crimp heats, it can expand and might not make a proper connection anymore. Alternatively, a MOSFET could be overheating and shutting down momentarily.
