Use distilled water and devise a system with a lid to keep it clean. It is also a good Idea to add a flow sensor switch in line with the “laser on” pushbutton so if the water flow stops the laser will not fire!
#3, no chart that I am aware of, although if you check the Materials & Settings section of this group you will find tests people have done & uploaded images/settings used.
@Ariel_Yahni_UniKpty the spoeds look too fast and power too low for the table at the end of that Reddit link. I’m usually in the 10-20mm/s speed range and 12-18ma power for most 1/8" cutting and half that speed and/or multiple passes for 1/4" wood stock.
@Ariel_Yahni_UniKpty Looks good as a basis, but as Jim mentions, those speeds/power settings seem a bit off compared to my own experience. I tend to use 10mA power & 25mm/s & 2 passes for 1/8" (3mm) plywood & it usually does a pretty good job of it. 500mm/min that they suggest is about 8-9mm/s, which seems overly slow & likely to cause excess charring on the edges. I prefer to do extra passes to minimise the charring.
