You can now manually edit a filter in the serial port Console window. This has been an issue for Grbl users because Grbl requires the browser to send so many repeating commands. I also added $G as part of the default filter on Grbl to reduce headaches. +jpadie You should do the same in the /jpadie workspace.
thanks @jlauer . I overloaded the init call a while ago in the jpadie workspace.
i was a bit surprised, truth be told, because the workspace already had a filter built into it (in the recvNewLine method) but somehow that was not capturing for the chap that was complaining about it a week or so ago.
