You know that moment when you realize you've just figured out how to do
You know that moment when you realize you’ve just figured out how to do something, whether it’s code or hardware, and a fraction of a second later … it’s gone? Yeah … that just happened. Soooo I’m connecting several strips to a single board, and trying to run code that’s displayed across all the strips. Think of a matrix made out of individual strips that are not daisy chained together. How can I run something like noise across all of them so it actually looks like a matrix?
When this happens to me, I find it usually happens because I was actually wrong, but for some reason, instead of realizing why, my brain instead just experiences a disconnect and jumps to a new idea (and tries very hard to delete the old one). Eventually I can work out the original idea and then I can see what was wrong. Very annoying because it makes me feel like I need to chase down an idea and I can sometimes spend a lot of time on that, and all only to find out it was wrong.
So your strips are laid out like:
pin0: 0…n
pin1: 0…n
pin2: 0…n
pinm:0…n
We’ll call (pin0, 0) your origin; pinm is your max y value (height) and n is your max x value (width.)
// ledsArrays is an array of pointers to the leds arrays of each pin. This probably isn’t quite the right syntax but you get what I mean
pin0leds = CRGB[n];
pin1leds = CRGB[n];
pin2leds = CRGB[n];
pinmleds = CRGB[n];
CRGB[] ledsArrays = {pin0leds, pin1leds, pin2leds, …, pinmleds);
pixel(int x, int y, CRGB colour) {
CRGB *leds = ledsArrays[y];
leds[x] = colour;
Also, as a side note, is this multiple-leds-arrays-off-multiple-pins feature in the 2.1 branch now?
One Array Many Strips. Works with noise, palette, funkyclouds. Breaks after 255 leds though (havent troubleshooted yet).
leds[NUM_STRIPS * NUM_LEDS_PER_STRIP]
FastLED.addLeds<CHIPSET, 2, GRB>(leds, NUM_LEDS_PER_STRIP * 0, NUM_LEDS_PER_STRIP);
FastLED.addLeds<CHIPSET, 14, GRB>(leds, NUM_LEDS_PER_STRIP * 1, NUM_LEDS_PER_STRIP);
FastLED.addLeds<CHIPSET, 5, GRB>(leds, NUM_LEDS_PER_STRIP * 7, NUM_LEDS_PER_STRIP);
