You might have to turn up your volume to hear this.
You might have to turn up your volume to hear this. At about 24 seconds you will see the red light dim a little and if your volume is up you can hear a weird noise. This is when I turn on my hotbed. The red light flickers and the light on my bed will turn on for a second and back on. The bed gets hot as well but I’m not sure if this is a problem.
chad this look like a azteeg 5x ? if it is your heat sink goes underneat the pcb
Yes it is a Azteeg x5 mini, you mean the black long one for the stepper drivers
Yes it goes under the pcb
My heatbed wire creates a perceptible hum when it heating the bed - it has never caused a problem for me. I imagine it’s not dissimilar to the hum created by overhead power lines. I do know that you want to make sure the connections into the heatbed screw terminals are good every so often - I may have melted one by not checking such things regularly.
