Z-axis slide cleaned up and attached to 1/2-10 acme screw. Next to build Y.
Looks really good , good speed
Thanks!
Any reason why it hangs over more on one side, than the other?
Good eye Paul, I have that extra for the potential for two items, a place to potentially hang a 3D printer extruder, and an air hose for blowing away debris!
@Bruce_Lunde
Sometimes when I machine some materials I use an air blast as “coolant”. You know, stuff I do not want to soak with oil. It works good cutting Micarta. That stuff can really heat tooling up!
