Zubi Firmware 1.2 with auto baud setting and factory reset.
With this new update are available functions:
- Factory Reset
- Auto speed (115k / 250k) for both MCU owards 3dPrinter and WIFI module HLK-RM04. Speed configuration depends on the position of the jumper JP1.
Closed = 115,200
Open = 250,000
In detail:
Auto configuration speed (115k / 250k): Once power on the board, Zubi starts flashing led slowly for about 5/6 times, indicating that is starting communication with the WIFI module and configuring the communication speed toward the printer and the WIFI module
The speed (115k / 250k) depends on the position of the jumper JP1.
Closed = 115,200
Open = 250,000
Factory Reset function: After power on of Zubi, and only within the time that the LED flashes, remove / insert the jumper JP1 , to start the factory reset procedure, highlighted by the LED lit. With this procedure you restore the default configuration of the module HLK-WIFI RM04, the default speed of the serial port is 115K.
After completing the Factory Reset (takes a few seconds), the LED starts to flash again for 5/6 times and then be turned off at the end of configurazionhe selected.
The Factory Reset function is useful in cases of incorrect configuration of the module as a client of your home router, or if for some reason it is no longer accessible (WiFi off).
http://www.pic-ap-board.eu/forum-zubi/zubi-forum/5-aggiornamento-firmware.html#9
