3D Engraving Gcode Z-Inversion Python Program
This is different - it’s not a question!
It’s a free offer!
I just finished whipping up a little Python program that looks like it succeeded at inverting the z-axis values (that lie below zero) about a Z-level mid-point.
Back story…
Just got a SainSmart 3018 up-n-running, made a fine-looking ‘dragon.nc’ in a block of hardwood (after using G-Code_Ripper to scale down Z a bit).
I’m also a potter - saw that the dragon would be better as a negative - could then use it to press clay into - make tiles.
BUT… G-Code_Ripper did not do ‘negative scaling’. :frowning:
SO… after a couple hours with Geany and python, I have a program. :slight_smile:
How do I get it to you? Where do we upload things? Can you contact me if you want to have a look at it? It’s really small - doesn’t do much but seems to do it well. I say ‘seems’ because my 3018 is still busy for a few hours so haven’t actually tested it yet, but the gcode file looks like it did the job.
OK - got a clue as to how to post code, so here goes…
#!/usr/bin python
#THIS PROGRAM offered by MakerMarlyn to fellow Makers.
#It can pick out the 'Z' if 'Zxxx' or 'Fxxx' is the last
# thing on a line - maybe following X,Y commands.
#Fortunately, this seems to be S.O.P. in G-code world.
# goes through a gcode file (fileIN) ,
# gets Z-value out of a line
# gets 'most negative' value (minZ)
# divides it by 2 - assigns to 'zMid'
#THEN...
# goes through fileIN again,
# if Z is below zero, flips Z about zMid,
# writes line to fileOUT = ("inv_" + fileIN).
# YOUR FILE NAME GOES HERE...
#Oh yes, it is good if this program and your file are in the same directory/folder.
fileIN = "dragon.nc"
fileOUT="inv_"+fileIN
minZ=0.0
fIN=open(fileIN,"r")
fOUT=open(fileOUT,"w")
#what's the minimum Z value?
with fIN:
    for line in fIN:
       L=line.strip()
        try:
            zSplit=L.split("Z")
            try:
                fSplit=zSplit[1].split("F")
                zVal=float(fSplit[0])
            except:
                zVal=float(zSplit[1])
                pass
            if (zVal<minZ): minZ=zVal
        except: pass
fIN.close()
print ("minZ=",minZ)
zMid=float(minZ/2.0)
print ("zMid=",zMid)
with fIN:
    for line in fIN:
       L=line.strip()
        eol="\n"
        zVal=0
        try:
            zSplit=L.split("Z")
            try:
                eol="F"+fSplit[1]+"\n"
            except:
                pass
            if (zVal<0):
                zVal=(zMid-zVal)+zMid
# set the precision -  '4f' is four places, '3f' is three places.
               L=zSplit[0]+ "Z"+"{0:.3f}".format(zVal)
        except:
            pass
       L=L+eol
        fOUT.write(L)
fIN.close()
fOUT.close()
Welcome! Thanks for suggesting sharing!
If it’s a single python script, you could just paste it into a post, like this:
```python
<paste your python between two lines starting with triple single back quotes
That will show the program here, kind of like this:
def hello():
    print("hello, world")
hello()
If you think this is something you would like to get bug reports on and fix over time, it could be worth posting it to GitHub and posting about it here.
Addendum… ‘Oh, what the heck, may as well scale the Z too.’
#!/usr/bin python
#It can pick out the 'Z' if it's the last
# thing on a line , or if it's only followed by the 'F'eed rate.
# SCALES it (Zscale)
#THEN...
# if Z is below zero, (scales it and) flips it about zMid,
Zscale=1.0
minZ=0.0
with fIN:
    for line in fIN:
        L=line.strip()
        try:
            zSplit=L.split("Z")
            try:
            except:
                pass
        except: pass
fIN.close()
minZ=minZ*Zscale
print ("minZ scaled=",minZ)
print ("zMid scaled=",zMid)
with fIN:
    for line in fIN:
        L=line.strip()
        eol="\n"
        zVal=0
        try:
            zSplit=L.split("Z")
            try:
                zVal=float(fSplit[0])*Zscale
            except:
                zVal=float(zSplit[1])*Zscale
                pass
            if (zVal<0.0):
        except:
            pass
        L=L+eol
        fOUT.write(L)
fIN.close()
fOUT.close()
