50W Blue Laser won't fire
There’s an issue I’ve been having for a couple weeks now. When I send a job to my Blue 50W laser…it moves a couple inches, stops and beeps. Never does the job or fires the laser. The controller display has never worked since I’ve had it for about a year. I control and send jobs to the machine using LightBurn…so if it’s giving an error on the screen I can’t see it anyways. I thought maybe it was the LB software…but even if I press the Pulse button as soon as it boots up…again, just beeps and doesn’t fire. I’ve recently changed the laser tube and also changed the power supply, so I can rule those two things out.
Is there anything else I should check…or would you suggest that it is the controller?
Updating this thread because it’s still not solved…still working on this issue.
I bought a new PSU from Cloudray and installed it…and the laser still doesn’t fire. I contacted them and they said if the buttons light up on the PSU that the issue has to be with tube. Well it was a new tube as well, maybe a month old from Light Object. But they insisted it has to be the tube if I press the test button on the PSU and there’s no beam at the tube. So I bought another laser tube, installed it and still nothing. No beam at the tube when I press the test button on the PSU.
I currently am still at step one here since I’ve changed the PSU and the laser tube twice and it’s still doing the exact same thing (not firing) it was before I changed those things.
Any other ideas will be appreciated…
Gonna take a look at the water flow sensor next. Have ordered one on ebay and will update this thread with the results once it arrives and is installed.
The water flow sensor you should be able to test with a multimeter.
