Blue wire to DIN- was the solution! Now that I know where it came loose from I know I did NOT disconnect it deliberately - - it came out on its own.
But all is now good and I’m up and running!
Thanks again!
Did you get the board to work? I have 2 and no luck getting either to work.
Never mind. Have to read the post to the end.
It has only been 15 months since you wrote this and I finally got around to doing something with it. I got it downloaded and extracted into two folders labeled 0 and 1, and described on a Win 10 machine as an MBR file and an ISO file, respectively. Now what? I assume I need to use these files to create a micro SD card that duplicates the micro SD card that originally came with my all in one controller, but not sure how to go about that.
“extracted” — you don’t want to “extract” it. You want to write the whole image file, as is, to an SD card, using etcher.
Michael,
Thanks! You guys teach me more every day.
