Beaglebone AI:building android 9 failed
hi,
I tried to build aosp-9 for BB-AI, refs the below link :
Processor SDK Android Software Developer’s Guide
i did everything as the user guide said,my repo sync finished successfully:
repo sync -c
Fetching projects: 100% (680/680), done.
Checking out projects: 100% (680/680), done.
repo sync has finished successfully.
when I try to build aosp,
make -j8 clean
. build/envsetup.sh
lunch beagle_x15-userdebug
make -j8
I got failed:
BBB-AI/SDK/android-sdk/board-support/aosp-9.0$ make
PLATFORM_VERSION_CODENAME=REL
PLATFORM_VERSION=9
TARGET_PRODUCT=beagle_x15
TARGET_BUILD_VARIANT=userdebug
TARGET_BUILD_TYPE=release
TARGET_ARCH=arm
TARGET_ARCH_VARIANT=armv7-a-neon
TARGET_CPU_VARIANT=cortex-a15
HOST_ARCH=x86_64
HOST_2ND_ARCH=x86
HOST_OS=linux
HOST_OS_EXTRA=Linux-5.4.0-91-generic-x86_64-Ubuntu-18.04.5-LTS
HOST_CROSS_OS=windows
HOST_CROSS_ARCH=x86
HOST_CROSS_2ND_ARCH=x86_64
HOST_BUILD_TYPE=release
BUILD_ID=PPR1.181005.003
OUT_DIR=out
ninja: no work to do.
[1/1] out/soong/.bootstrap/bin/soong_build out/soong/build.ninja
FAILED: out/soong/build.ninja
out/soong/.bootstrap/bin/soong_build -t -l out/.module_paths/Android.bp.list -b out/soong -n out -d out/soong/build.ninja.d -o out/soong/build.ninja Android.bp
error: system/tools/hidl/test/vendor/1.0/Android.bp:11:15: module "hidl.tests.vendor@1.0_interface": interfaces: Cannot find interface android.hardware.tests.baz@1.0
ninja: build stopped: subcommand failed.
19:12:57 soong bootstrap failed with: exit status 1
#### failed to build some targets (1 seconds) ####
anybody know how to fix it?
Thanks very much!
If you are building on the BB-AI then I would not be running 8 building processes on a 2-core system. If cross-compiling I would look very closely at the build output to see that everything is being sourced from the correct cross-compiler and libraries as opposed to grabbing system build tools.
I would also try again(with -j1 or -j2) and watch carefully for any errors or warnings which might explain the missing interface system. Same goes for when your run the envsetup to make sure something in the setup didn’t error out.
So that answers that question.
I’ve never built it.
@yangchao315, not much of the BeagleBone community followed the Google+ rescued content to Maker Forums. Last I checked, the most active community I saw was the BeagleBone google group.
