Does the supplied CD with corel draw and install work on an apple mac?
Can I use illustrator?
Non of the stock software will work on a mac directly unless you use a virtual machine like parallel desktop or upgrade your stock board and use LaserWeb
Thank you Ariel. Is there download software and drivers which will make it work or do I need a PC?
If you don’t change the stock board you will not be able to natively run on a mac
I am going to google ‘stock board’
Thank you for you help.
You can find here where to download ColerDraw and CorelLaser to use on windows Link to Corel draw and corellaser https://plus.google.com/116150448511980225555/posts/27ny6QGE3Bg
I now have a pc laptop. Is the disk supplied any use at all? I am just unzipping the rar files.
The file has unzipped. Corel Laser has installed. Corel Draw is asking for a serial code? Any ideas?
There should be a code generator inside the zipped file.
I found the code in a file on the disk. Install is going ahead at the moment.
Coral draw did not install properly. Only one percent to go and it froze.
Wow that’s sad
I know.
Trying it again. Not the easiest thing to set up.
Ok. Coral Draw seems to have installed. Whats next?
CorelLaser, this is the pluging that will run inside corel draw and control the machine
done.
i have drawn a lovely circle. red 255. 0.1 and it seem to have made a mark on a piece of wood. well at leat thats a start. Laser alignment time
That would be the most important part of all. Good laser aligment. For reference you should at least be cutting 3mm ply at 10mm/s with 10mA of power
great ok.
@Gail_Lingard did you set the board ID in device initialization?
