@trevorflowers - I have an old microscope (I am a bit of a collector), but not the micrometer stage.
or as @dougl says - I was just using settings that make the line width hard to control and the 2 and the 10 are just statistical flukes
… Oh well… I thought that I was being so clever…
Shows why scientists should always open up their work to criticism and should never work in isolation.
Today I printed the same part specifying 3 external perimeters, outer perimeter printed first, perimeter width 0.44 mm (=110% of 0.40, the nozzle diameter).
The result is almost exactly the same as reported before. The external dimensions of the calibrator thing are ~ -0.05 of 25x25x8 (i.e. ever so slightly undersize) - the 2mm and 10mm drills pass through the respective holes, the 8mm drill is a tight fit through the 8mm hole and the 4 and 6 mm holes are too small for drills to fit at all. The drills are all about 0.10 mm undersize, according to my Vernier callipers (the fact that I am working at or near the least significant digit of my cheap no-name Vernier callipers has not escaped me - but its the best that I have)
All print speeds were quite slow, unfortunately the small perimeter speed was not as low as Michael suggested (maybe next time
The prints by the way are beautiful (unblemished, even surfaces, etc).
The discrepancies are not large - but enough to cause problems when tolerances are tighter than ~ 0.2-0.3 mm. I have a hunch that if I increased the diameter of the holes further, the sequence will repeat - that is some holes will be under and some will be over nominal size by a small amount that is less than the line width. Unfortunately that’s when I have had problems, as I don’t have drills that are bigger than 12 mm in diameter.
Even though I found no noticeable difference between Cura and Slic3r wrt to print accuracy, I am impressed by Cura in many respects and will now use it exclusively.
I’m not sure how Cura handles calculating line paths but here’s a blow by blow if what Slic3r does. Pay particular attention to the very last section, “defaults” where it states the default extrusion adjustment for perimeters(only one side of the line path interfaces with another line path.
https://manual.slic3r.org/advanced/flow-math
So how you want your holes is adjustable in Slic3r( and Prusa Slicer ). Some prefer to run a drill bit through holes so prefer some extra extrusion on the perimeter so when the bulging end of the exposed extrusion path is removed by the drill, there’s a near solid wall in the hole. Others, who might use self tapping screws in these holes prefer the undulating inside surface for the threads to cut into and push aside on insertion.
When I first started 3D printing I tried as many slicers as I could find and since I was learning, I wanted as many setting options exposed as I could and that lead me to Slic3r. A few years later a friend with a Prusa printer told me about the Prusa Slic3r and I’d put it off until one day I read how it was Slic3r under the hood with modifications(all provided to Slic3r if they wanted them) so I tried it and found I liked it. Prusa was moving faster than Slic3r with updates like having variable layer thicknesses and better support implementations so I’ve been using Prusa Slic3r and now Prusa Slicer.
Just over a year ago Stratasys purchased Ultimaker who was the corporate entity behind Cura. Stratasys promotes Cura with their Makerbot line of machines but lots of the literature I saw from them promotes their non-free commercial slicer for their FFF machines. If I were a Cura user I would periodically look at the git repository and observer the update frequency to keep confidence in its future.
Great job on doing your own tests and analysis and sharing it. It’s a great way to learn your machine, slicer and FFF processes.
And thank for your generosity with your replies - I learned a lot from you.
I started using Slic3r when I was given the Tevo Tarantula for my birthday - The Tarantula is basically a DIY kit - (imagine getting a 3D printer form IKEA) - and they recommended using Repertier Host as the software - Repertier in turn offers Slic3r, Prusa or Cura Engine as the slicers, and I chose Slic3r and never really had any cause to change as I was happy with it for the same reasons as you.
Recently a local hobbyist store was offering the Dobot Mooz 3 (3 colour, single nozzle) delta printer for $149 AUD . I was always intrigued by delta printers and this price could not be passed up (Fully assembled, great cable management, touch screen controller, glass block build plate, 3 steppers for movement control with lead screws, 3 steppers for filament feed control, and 3x250 g of filament as well as spool holders).
As is the case with many of the things that are made in China the instructions and support are very limited and the manual only has recommended settings for Cura. I did not want to spend too much time figuring out how to set it up in Slic3r so I downloaded Ultimaker Cura.
While playing with my new delta printer I noticed that an M10 thread that printed with it took and M10 bolt without tapping. The same happened when I used Cura to slice the same part for the Tevo. So I thought the solution to the previously reported problems was the slicing software. You know the rest of the story.
There is a lot to like about Slic3r… but I like the clean modern interface in the Ultimaker Cura and it’s print preview implementation.
I’ll post again if I get any further insights - at the moment I feel that never has so much been said and done over 0.2 mm ;-).
Have you considered your microsteps/mm. could they have anything to do with the inaccuracy. Just a thought.
