FreeCAD - how to create a 2 part mould of 3rd modeled part
Worked surprisingly well. Did a fit test and found out I should have used the calipers on the hole in the pump rather than take the diameter of the rubber. I missed by ~1mm and the valve blows out of the end of the pump. Parameterized so will add 1mm to stem diameter and plug diameter.
If only this video had been shot a bit earlier! :smiling_face:
Cool, I’ll have a look. I have been trying to use the Part wb over Part Design for little parts I’ve made.
