Hello everyone. I just broke my hotend...
Hello everyone.
I just broke my hotend… so i searching for buy a new one. This time should it be for 1.75 and not 3mm…
any rekommendation. i have all the heat stuff and thermistor its working.
i’m not impress of j-head. wanna try an other one.
fillament 1.75mm noz 0.4-0.3
Open for suggestions. thans!
Where do you come from
Sweden
Here in austria, there is a reprap website (reprap.cc) which sells hotends
but I can shipp to diffrent office there i work. like US, china.
http://reprap.org/wiki/Printing_Material_Suppliers
Its only for filament, but you could find some hotends i guess
Thank you!
No problem :slight_smile:
do you hava a reprap?
From what I’ve heard the e3d hotend is pretty good, it’s all metal and has the same mounting system as the j-head, so you wouldn’t have to worry about it not fitting your current printer.
thanks. i have look at it. http://e3d-online.com/E3D-HotEnds/E3D-V5-1.75mm-Direct-All-Metal-HotEnd
and from youtube it’s look nice. mabye thats the one. but it is only a 1.75 or is it 3mm and petf pipe to 1.75 ?
Makergear makes a great hot end.
They make them in both sizes, with no ptfe.
ok. greate. . do I need a fan to the E3D ?
I think so, but it comes with a fan and a mounting bracket for the fan.
@Patrik_enerstrand
No.
I dont own a reprap yet.
But in definitely going to buy a mendelmax
ok:). i had a prusa but change to air 2.
http://www.thingiverse.com/thing:74830
now i only have problem with the hot end. rest is working fine :slight_smile: it was sooo much better with a static frame
thank every one for the help i have no order the E3D :slight_smile: hope it.s workign well! even for me
@Sanjay_Mortimer is a developer of the e3d and a very active contributor to the community. I don’t own one YET, but I’m impressed by what other’s have posted about its performance and the level of support that is provided
I had heard tell that the e3d hot ends needed a little more polish to be used without PTFE inserts. I think @ThantiK and @Whosa_whatsis were discussing this recently. I still love my j-head, but have never tried anything else.
@Tony_Olivo , nah, the E3D hot ends work great without PTFE inserts. It was the QU-BD hot ends that didn’t work so well because of the lack of polish on the inside of the barrel, and other things that just simply weren’t accounted for. Sanjay accounted for all of this in the E3D hot ends and I couldn’t recommend them more. The QU-BD hot ends, on the other hand… I could recommend them, as long as you source the heat-breaks from someone else.
