Help! I need to source a large, high torque easily source-able servo motor. The end goal for this is to attach it to a printed gearbox to move a very large humanoid leg.
It needs to work something akin to the image below, which is what I currently use for the arms in my bot. This is not fast enough with enough torque to drive a leg.
Can anyone point me in the right direction?
EDIT:
the motor I use at the moment is a super large hitec 20kg servo. This was the best in class for reasonably priced servo tech, but it is not enough.
Hit the RC hobby sites. There are quite a few high torque, high strength, metal gear servos available these days.
I see ads for them in every issue of Robot and Servo magazines.
I should have noted I have checked the obvious places I will be designing a whole new gearbox, so it doesn’t even matter too much what servo it is, as long as it is reasonably quick and high torque
@Andrew_Plumb
10kg/cm would be torn apart in seconds
I currently use Hitec servvos that pull 25kg/cm. Problem with these servos is that in order to maintain speed with good output torque, the input servo needs to be good and strong.
Cheers!
Why use such a servo? Get a normal BLDC with a planetary gear, take an incremental sensor and build a strong “servo” that way yourself! It’s a bit more expensive but you’ll definitely have a much stronger drive than with a servo off the shelf.
@Hendrik_Wiese
It is something that I have thought long and hard about. Especially as I run the OpenServo project, which is designed to do exactly what you propose.
Issue I have is I want to keep this project as simple and commodity as possible so people can easily recreate it. The less custom stuff the better.
I am not ruling the idea out at the moment
Thanks for the input!
@Marcus_Wolschon
I could just as easily mill it. I have a 3 axis. It isn’t so accessible to others once you start asking them to mill pieces of a machine, or stump up £££ for a gearbox. I am working on an experiment of how much of a robot design can be printed
