I was just able to recover a print that was 44 hours in and
I was just able to recover a print that was 44 hours in and had a nozzle jam. I measured the print height, went into the G code of the print, and found what layer was at that height. I deleted everything previous to that layer and added a little bit of code before it:
G28 X Y (to home the X and Y Axis only)
G1 X0.0 Y0.0 Z140 (move two mm above the layer I wanted to start on)
I copied the first coordinate out of the layer I wanted to start on, and added two mm to the Z axis so it would move into place while staying above the print.
G1 X84.050 Y47.834 Z140
Then I left the rest of the code as-is. I set the nozzle and bed temperatures manually, and started the code I had modified. It did exactly what I wanted! I ran the first layer 5 degrees hotter and at 10% speed to try and remelt some of the previously left print. After the first layer, I turned on the part cooling fan, turned the nozzle back down 5 degrees, and ramped it back to 100% speed! Seems to be running like a champ! I’m glad I have that flexibility with this printer.
Thingiverse?
@Chevrolet_Diesel_Nat https://www.thingiverse.com/thing:919475
Confused
Nice save! And nice looking print so far.
Obviously the picture is of the state you found it in after printing air for some time. Do you have a picture of the saved file continuing to print?
cool
Nice save! 44 hours 3/4 in? That’s mad :grimacing: What was the total print time and layer height?
I /never/ had a nozzle jam with the old Printrbot hotend or a J-Head. I suppose it’s something to “look forward to” when I start using an all-metal hotend… :wink:
That’s pretty amazing. I’m curious to see the final quality of the product.
Very cool!
@Kevin_Danger_Powers after a few layers, it does look like I could have squished the nozzle into the print a little further, but I was worried about knocking the print off the bed by going too deep in. Overall, I think it’s a win. I’ll post pictures of the seam when it’s finished.
@Kevin_Danger_Powers this is after going for another 8 hours you can see the seam, but it’s really not horrible. In fact, in some parts of the print it’s barely noticeable from the normal printing lines.
Commenting for updates. I want to see how this turns out.
@Jeff_Parish I only made one copy of the modification, and it’s currently in the printer…You’ll have to wait till it’s done. :grin:But I will post it. :sushi:
@Petr_Sedlacek total print time will probably be around 72 hours. It’s a .4mm nozzle and I’m doing 0.1mm layer height. It’s currently still running. I’ll keep you updated.
What printer is this??
@Greg_Dimas I’m using a ReliaBuild3D RB2 (Formally Rigidbot). The new owner (@Heath_Harper ) has made a lot of improvements to the original design. They have a lot of advancements in the electronics, stability, and user interface (and it’s been a dream compared to my original Prusa i3). Feel free to check it out at http://www.Reliabuild3D.com. If you want to get one, let me know. I have a code that can get you $150 off on certain sets. http://www.Reliabuild3D.com
ye dude I did the same, I had to remove the part of the script that says to home the head while mozing z plate, I programed it to moze z to the bottom first then zero the head then move z to the position then resume layers. Somthing to be aware of to not knock off the print or bump the head into it :smiley: *remove priming script too
