Just checking whether anyone else is having issues as well… I just downloaded and installed 4.0.724, and now I cannot open SVGs that opened just fine before.
Even known good workspaces don’t work anymore?!..
Got the latest pre-compiled 64 bit binary… FE 4.0.724; BE 4.0.63
I’ll wait for that before doing a clean wipe and reinstall…
Brilliant! Will test ASAP!
4.0.68 installer still reported a backend of 4.0.63… Just reverted to the 4.0.42 installer version (cannot see the FE version on that, as the ABOUT pane won’t work there) and the SVGs open normally again…
I will try the live edition (and if it works, I will also try the LW-Commserver path) next
It’s 4.0.721… Seems pretty recent to me? :o
Anyway, the weird thing is that 4.0.721 on https://laserweb.github.io/LaserWeb4/dist/ opened a simple SVG once, and after an (accidental) page reload it doesn’t anymore… Will investigate further!
Note for anyone following this thread: we looked at his SVG. It’s badly corrupt; several other tools can’t open it. We may have to recommend people avoid using Corel’s broken SVG export and use Inkscape to convert instead.
But these test I am doing with a new, simple, InkScape drawn SVG!
It’s just 3 ellipses, 2 rectangles…
I can open it in the version that installs with the 4.0.42 installer (11/3/2017), but not in the 4.0.721 on live or the 4.0.724 from either the 4.0.63 or 4.0.68 installers…
Ah. I didn’t know about the simple SVG.
Very weird. The live version works with my files. Please post your 3 ellipses, 2 rectangles svg.
I should probably have been more clear, but yeah, my Corel SVG testing (which I did specifically for the one issue in GitHub) is separate from this generic SVG test, that I discovered as I upgraded to the latest…
Aside from running the uninstaller (from %userdata%\AppData\Local\Programs\lw.comm-server), is there anything else I can clear out to ensure a clean reinstall?
I just want to figure out what is causing the issue, so it can be at least documented on how to fix it, or prevented in the code…
(Esp. as it works fine in an older build!)
This is the live version. Very odd that it’s not working on your machine. Try clearing the browser cache and reloading the live version.
On my gamerig 721 live works fine as well
Testing the other machine (the one connected to the laser!!!) again!
Cleared everything but passwords on the browser on the Pipo (‘until the beginning of time’), no difference… Now installing Canary for testing…
So, I’m confused. Cesco stated that the Saved Workspaces didn’t work either. Is that related? Does the workspace simply reload the SVG or use what it imported?
and… Should I hold off updating or is it good now?
