Mark Rehorst: 3d-printable wire twister set built around wago wire nuts
Very clever combination of ideas here!
I never found it complicated to just put the two wires in the end of the drill and clamp it down on the other end. I would then cut off both ends that are damaged from the clamping and strip them. No need for fancy tooling!
Ditto.
Regarding the Wagos, just a couple of days ago I had no idea what Wagos were until I watched a video on Wirenuts vs Wagos Which is better. Today Wago shows up again and it wasn’t because of an ad bot following me.
