Problem Initializing K40 whisperer
Hi all, I recently purchased a cheap Chinese K40 Laser and are having trouble getting K40 whisperer to initialize the laser. The laser draw programme that came with the laser works but I would much rather use whisperer.
Any help would really be appreciated.
You’ll have to describe what the trouble is, folks here aren’t great at mind-reading. :rofl:
Welcome to the Forum :slight_smile:
Are you trying to do a windows install? If so did you go through all the installation instructions?
http://www.scorchworks.com/K40whisperer/k40w_setup.html#windows
Sounds like you might not have the correct usb library installed.
Thank you for that will check that out today and thank you for your so quick reply.
Sorry I should have taken more time in my describing my problem.
Hi Ned, You were absolutely correct as it was the incorrect USB settings. I had not followed the windows installation instructions. After receiving the package I was super eager and in to much of a hurry to get it the K40 working. I have to add that I was also happy that there was someone like yourself to understand what I was in need off. So a very grateful thank you again.
Regards from Oz, down under Col.
Turns out I was wrong and @NedMan is a mind reader! :rofl:
