@Daid_Braam Most machines are designed to a withstand certain loads and pressures (or at least should be). Unfortunately, sometimes this they are taking beyond the range because of other factors (like lack of software safety checks?), but that doesn’t meant it’s not tough enough for the job it was designed to do. In this case, the Z travel was taken beyond what it was designed for and with extra powerful motors and good torque on the Z screws, something has to give. If you want an unbreakable printer, would may need to make every piece out of steel. And yes, we use delrin in some areas where needed…
We are always open for discussion (which allow for disagreements too) and we thrive on improving things, but in this case, problem is not the acrylic, it’s was the software and controller that didn’t tell it to stop before the limit…or maybe we should just cut down the Z screws a bit more to not go beyond and lose a little height…(By the way @Jonathan_Foote if you loosen the top bar and remove it or slide it up a bit, you can have an extra inch of build height…)
I hate to tell you, but no design is perfect, nor will ever be. We all know this, but we aim for some goals we think are important and we try to reach them the best way possible. I can’t say our machines are perfect, but we do try hard to make them the best possible while keeping them robust, affordable, and open.
But despite this little discussion, we do love your Cura slicing engine and the accuracy it has, we definitely don’t think it’s crap. Although not perfect (which no slicer is anyways), we do think it’s very high quality as far as the math, options and the intelligent algorithms. Either way, thanks for making a great piece of open source software!
We are also looking forward to your new Ninja Kittens project for the CNC world (which badly needs a simple but good G-code generator that hopefully can work on Mac)…
But just like your motivation with your Ninja Kittens, when we experience something important that we think should be better, we try to make it better.
On a somewhat related note, if you don’t know about him, check out Panucatt devices (Panucatt.com) He’s making some great CNC controller boards that you may want to work with (I’m sure he may consider some freebies for you).
