Where to start?
Hi all.
I’m new to cnc type work and hoping for some advice.
I play tabletop games and would like to make some marker pieces, and some paint stations I’m planning on getting a 3D printer too for terrain but having the ability to cut MDF would be great.
Any recommendations on a good desktop starter unit?
Welcome! Tell us more! :relaxed:
Here are some of the variables to drive that decision:
  • What is the maximum length/width you want to cut?
  • How much vertical range do you need?
Most routers will be fine for cutting MDF, but routing MDF will create a lot of dust. Do you have a place where you can cut where dust won’t bother you? You might want to consider units that you can connect a vacuum to collect dust.
Do you want a cheap unit that will get you started and learning more, with the expectation that if you do a lot of this you will replace it? Or are you looking for quality to last a long time?
Hi there,
pretty much I’d like to make things like this:
https://www.hobbies.co.uk/brands/hobbyzone?utm_source=google&utm_medium=cpc&utm_campaignid=12767151751&utm_campaign=&utm_term=&adid=514986715893&addisttype=g&matchtype=b&gclid=CjwKCAjwwsmLBhACEiwANq-tXA-9LLGK72VF4BykLqGFMCw5mnQZA6R7nymxtaDjFz576MJTEPnvNBoCBngQAvD_BwE
Things I can put on my desk and help me organise paint and stuff.
Like to keep cost low but of course I’d like a machine that’ll do the job and do it well. So I understand quality costs money.
I’d be putting this in my garage, and would extract dust as a side project I think. Would have to come up with something there.
There’s basically classes of cheap routers that are based on the size in centimeters. 3018 means 30cm x 18cm bed size; 6040 would mean 60cm x 40cm bed.
Might consider reading this thread on a 3018-class router:
