hi, dougl
her is the link to video i uploaded my youtube channel.
hi,
can the setting for X,Y be the same Z or need be different?
im asking because the setting from what you talk about. i notice Z setting are different from X,Y below.
For What It’s Worth( FWIW ) I found a guy who has a 3040t-CNC who put GRBL on an Arduino Uno and used TB6600 drivers and NEMA 34 steppers. He had these settings for GRBL: Notice he also is using 400 steps/mm
$0 10
$1 25
$2 0
$3 0
$4 0
$5 0
$6 0
$10 1
$11 0.010
$12 0.002
$13 0
$20 0
$21 0
$22 0
$23 0
$24 25.000
$25 500.000
$26 250
$27 1.00
$30 1000
$31 0
$32 0
$100 400.000
$101 400.000
$102 400.000
$110 2500.000
$111 2500.000
$112 500.000 <—
$120 30.000
$121 20.000
$122 10.000 <—
With $110,$111 and $112 you set the maximum speed of x/y/z (called feed).
It does make sense to have the z-axis slower because you will not move as far in z.
The max. speed setting is only used for fast moves while jogging (G0). For machinig operations (drilling, cutting…) you will use G1 to G3 commands with param F, which is the feed in mm/s.
For example:
A cut of a streight 100mm line in X+ direction with 2000mm/min feed is “G1 X100 F2000”.
But be aware that there are two modes: absolute and relative!
With $120, $121 and $122 you set the acceleration of x/y/z, so how quick it is accelerating to the set feed. The maximum possible acceleration depends on you machine (motor torque, axis restistance…). Your acceleration settings seem to be ok, as I saw/hear in your video.
There are also the settings $130,$131 and $132 for setting the maximum travel of your axes. If your x axis can move 400mm from left to right, then set $130=400.
Hi, cprezzi
Thank you., for clarifying that. i couldn’t get answer from other source support.
The GRBL Wiki (Home · gnea/grbl Wiki · GitHub) is a good source to get infos about grbl and configuration.
Hi,
Thank you for your support guys. dougl & cprezzi., i appreciated.
So here is outcome of my custom build. Look over the video and let no if everything look good.
the final setting, after trying parameters setting…
$100 400
$101 400
$102 400
$110 800
$111 800
$112 400
$120 30
$121 30
$122 30
I’m having problem with probing, it dosen’t work properly.
looks good and even though that’s quite a small task for such a big machine, it does show that you have things square, level and have the controller and CAM setup nicely. Well done.
